Receiving serial without interupt PIC18F25k50
maniac84
Full Member level 6
Full Member level 6
Hi guys,
I want to do a serial receiving without using the ISR in my PIC18F25k50. I will use my main() loop to do the receiving.
Anyone know how? I had searched the net but all are with interrupt.
hello,
If using pooling instead of interrupt you can loose some caracteres if all caracteres are collapsed,
no times between caracteres and big amount of data..
Even using polling , check error Overflow or Overun flags...
Good Result in pooling depends also of
- what is the link speed ? 1200 bauds .. 19200..more ?
- what is the FOSC speed ? 1MHZ..64Mhz
I'm writing something like this in main() loop:
		if (PIR1bits.RCIF==1)
			rxbuf = RCREG;
			RS485RXDATA[n485RxDataPos++] = rxbuf;
Is it ok?
Do we need to clear RCIF flag after reading RCREG?
My baudrate is 9600 and the crystal I use is 20MHz.
u need to clear
  PIR1bits.RCIF    =    0
this flag after reading RCREG .
			rxbuf = RCREG;
Is it ok?
This is ok. But with a big if!
Since you are using a 9600 baud rate, approximately 1 byte will arrived every 1 millisecond. If you can guarantee that your above code statements will execute every 1 msec, then it is ok.
But if your program loop does other things other than to wait for the received byte, then pure polling/looping may not be a good solution.
You have to use RX interrupts together with circular buffer to make sure that no received byte is lost.
Actually, my program loop still will have to do USB transmission.
The data that I received from serial will straightaway transmit using the USB port. I do notice some missing protocol from the USB port. Like for example if I got 20 protocols send to serial port, my USB port only manage to transmit out 7 protocols.
