vitruvius
Newbie level 5
Hello,
I am sending some data from one Atmega644P to another Atmega644P consecutively. The first three bytes are SYN(0x16), DLE(0x10), and STX(0x02). On the receiving part, I made a state machine to control if I receive those bytes correctly.
When it is in DLE_1_s state, it goes directly to the "else" statement, even though the data is 0x10. Why is this happening?
I am using Peter Fleury's uart library.
This is the flow chart diagram I am trying to implement:
This is the code:
Thank you.
This is the code:
int main(void)
DDRD = 0b11111010; // PORTD input/output.
DDRC = 0xFF;
uart_init( UART_BAUD_SELECT(UART_BAUD_RATE,F_CPU) );
sei();
unsigned int rec_char;
char buffer[7];
while(1)
rec_char=uart_getc();
switch(state)
case SYN_s:
if ((unsigned char) rec_char == 0x16) // SYN
state=DLE_1_s;
else
state=SYN_s;
break;
case DLE_1_s:
if ((unsigned char) rec_char == 0x10) // DLE
state=STX_s;
else if ((unsigned char) rec_char == 0x16) // SYN
state=DLE_1_s;
else
state=SYN_s;
break;
case STX_s:
if ((unsigned char) rec_char == 0x02) // STX
state=TARGET_NO_1_s;
state=DLE_1_s;
else
state=SYN_s;
break;
Thank you.
