Coper
Member level 4
I need to measure the temperature with a resolution better than 0.1C, an absolute accuracy of 0.5C, and at a rate better than 5Hz. Sensor in a small max three-pin case, will be connected with a cable of approx. 30 cm. Measured temperature range from room temperature to 95C, it is mainly a range of 65 to 85C
I was intrigued by the TC1047A, but
If I were to calibrate the entire system at one point, for example 50C, is there a chance that it will also meet the long-term required parameters?
Thanks
- High Temperature Converter Accuracy: ± 2 oC, Max, at 25°C, but according to Figure 2-1, a supply voltage higher than 2.5V causes the main error. Msy be use supply voltage 3,3V over diode 3.3V – 0,7 = 2,6V
- according to Figure 2-1, a supply voltage higher than 2.5V causes the main error and output voltage 0-100C 500mV to 1000mV
Thanks
