Reading decimal numbers (with floating points) from a text file (Verilog)
chikaofili
Junior Member level 3
Hello,
What is the best way to read a textfile that contains decimal number (eg. 2.987) into verilog?
At the moment, I convert the values to hex using matlab (using num2hex). But when I use readmemh, it assumes that the 32bit variable is a 'regular' number and not a floating number?
Any suggestion will be greatly appreciated.
Thanks!
