READING A PUSHBUTTON & display on LCD
fantabulous68
Junior Member level 2
I recently got a pikit 2, its the 1st time that im using push button switches.
im using 4 pushbuttons.
All i want for now is:
when i power the circuit The LCD displays "infrared liquid level detector", so the lcd code and initialising is working. BUT
when i press ENTER/Settings button....i want "enter/settings" to display on the LCD. And that is not happening when i press the button. Please help me solve this problem....i attached a picture of how i connect the switch to the pic.
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
char input_sw;
#define HOME_SW RC2				//HOME switch
#define INCREASE_SW RC3			//INCREASE switch
#define DECREASE_SW RC4			//DECREASE switch
#define ENTERSETTINGS_SW RA4    	//ENTERSETTINGS switch
void init(void)
    OSCCON|=0x60; //set fosc to 4Mhz
	TRISB=0x00;
	TRISC=0xFC;
        TRISA = 0b10000010; 	// RA7 high imp, RA3 is serial out,
	ANSEL=0x02;            //set RA1 as analog input for GP2 sensor
	ANSELH=0x00;
	lcd_init(); //call LCD initialisation
 void read_input_sw(void)
 char input_sw2;
 input_sw = ((HOME_SW*8)+(INCREASE_SW*4)+(DECREASE_SW*2)+(ENTERSETTINGS_SW*1)); //create a binary combination of the input switches
 if (input_sw != 0) //check if any of the switches are pressed
	 DelayMs(20); //switch debouncing
	 input_sw2 = ((HOME_SW*8)+(INCREASE_SW*4)+(DECREASE_SW*2)+(ENTERSETTINGS_SW*1));
	 while (input_sw2 != 0) //if a switch is pressed wait for release
[COLOR="Red"]void home_screen(void)[/COLOR]
	lcd_clear();
	lcd_goto_L1();
	[COLOR="Red"]lcd_puts("INFRARED LIQUID"); //home screen message (line 1)[/COLOR]
	lcd_goto_L2();
[COLOR="Red"]	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)[/COLOR]
	read_input_sw();
	while(input_sw == 0)
		read_input_sw();
		switch(input_sw)
		case 8: break;
		//	ENTER/SETTINGS	button pressed
		case 1: {	lcd_clear();
		            lcd_goto_L1();
		[COLOR="Red"]            lcd_puts(" ENTER/SETTINGS ");[/COLOR]
		            DelayS(1);
		            lcd_clear();
					break;
                   default : break; //should any abnormalties occur
	return;
void main(void)
	init();	// initialise I/O ports, LCD
	while (1)
	home_screen();
I will suggest you to try to read one switch first and when you have done this successfully add another and so on.
When I read several switches from a port I usually:
- Of course set the switches connection as inputs.
- Read the complete port
- Mask the port to get rid of non wanted bits
- Check if a button has been pressed.
As you can see I read the complete port and then mask.
Again I strongly suggest you to change your code to read one switch first.
Added after 2 minutes:
Also what you need to do is to put a volltmeter on the switch connection to the microcontroller and make sure it will go to zero when pressing the button, if the voltage does not change, then check on the port configuration.
LaTeX Commands Quick-Menu:
