Read the data from a text file in Verilog HDL
velu.plg
Member level 5
Member level 5
chennai
i am new to verilogHDL.
now i want to read the data from a text file.
here text file contain data in integer format.
how can i read that integer data...
sir,this is my code...
module readwrite1;
reg [0:3]reg1[7:0];
integer fp,status;
initial
begin
fp = $fopen ("img.txt","r");
status = $fread (reg1,fp);
end
endmodule
here, file "img.txt" contain integer
but our output is(reg1)
reg1(0) 0001
(1) 1010
(2) 0100
(3) 1010
(4) 0011
(5) 1010
(6) 0101
(7) xxxx
what is the reason for getting 1010 at reg1(1,3,5..) ???
how can i read that data in correct format ??
Because you print it as binary in the code that you don't show obviously.
thanks for your reply.
sir, then what change can i do for getting correct output in integer form??
thanks for your replay....
i post my doubt after searching net source because i did not clear with it ...
can u give syntax or simple program code regards my doubt...
See the last link I gave you. There are some $display examples that you can just about copy verbatim into your code. Some initiative of your own required.
