kenambo
Full Member level 6
RE: Path Groups Encounter timimg analysis
Hi All,
While doing timing analysis, I have a different path group as "reg2reg_temp.2234" instead of "reg2reg" path group. The path group is supposed to be reg2reg right?
Why this change? Is there anything else I can do to change this?
And in timing report, I have some paths in which launch clock is leading edge of a clock and capture clock is also the same clock with trailing edge. and the phase shift also 0.
Is this common for a timing path? or am I missing something?
Thanks.
Hi All,
Thanks.
