christodoulos
Newbie level 5
- Joined
- Mar 19, 2013
- Messages
- 8
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,335
So I bought a small rc car with a small antenna, and its range, in which it operates, is to small (aprox. 3-4 meters). At first I thought I should extend the antenna of the car however the car couldn't support a larger antenna.
Then I thought that I could make some kind of a signal repeater using one more pair transmitter-receiver. So I bought another rc car (with an operating range of about 100m) and tear it apart. I tried to connect the transmitter to the receiver, using mosfets. The basic idea is when the recever receves a signal it activates the transmitter in order to re-transmit it. By putting this device close to the mini rc car I could expand the range.
However the mosfet circuit I design didn't work at all. I used as reference this diagram for the rx/tx : https://www.instructables.com/file/FMRBHT0GV0KKOQK and also I read this project :https://www.instructables.com/id/Arduino-controls-cheap-RC-car-transmitter/#step1. So I connected the pin 6 of the receiver to the gate of an irfz44, the ground of the receiver to the ground of the transmitter, the pin 1 of the receiver to the drain of the mosfet and the ground of the transmitter to the gate. The transmitter oparates with 3V source and the receiver with 6 V.
So, what am I doing wrong?
Thanks in advance
Thanks in advance
