# You need to modify the exports below for your platform.
# setting the path for cross compiler
export LINUXVER=2.6.37
export KERNELDIR=
export CROSSTOOL=
export PATH=${CROSSTOOL}:$PATH
export LINUXDIR=${KERNELDIR}/stblinux-${LINUXVER}
export ROOTDIR=${KERNELDIR}/uclinux-rootfs
export LIBUSB_PATH=${ROOTDIR}/lib/libusb
export TARGETDIR=${LINUXVER}
# USBSHIM=1 if kernel is greater than or equal to 2.6.18
# USBSHIM=0 if kernel is less than 2.6.18 or using DBUS kernel object.
export USBSHIM=0
# Machine and Architecture specifics
# TARGETMACH=arm is BE
# TARGETMACH=arm_le is LE
export TARGETMACH=arm_le
export TARGETARCH=arm_le
export TARGETENV=linuxarm_le
export CC=arm-linux-gnueabi-gcc
export STRIP=arm-linux-gnueabi-strip
export CROSS_COMPILE=arm-linux-gnueabi-
# DO NOT MODIFY BELOW THIS LINE
source ./setenv.sh
