Random effect for led dot matrix
deniah
Member level 4
Montenegro
I'm doing some experiments with 40x7 led matrix display and I'm trying to built effect where dots are switch on randomly to form letters.
Say, first column has to be 0b11111110.
First pass column looks like 0b00000000
Second pass 0b00001010
Third pass 0b10001110
forth pass 0b10111110
fifth pass 0b11111110
Every column must have own random pattern.
i've been struggling with this few days with no success.
Here is my code for static massage:
#define SHIFT_DATA       PORTB.F2         // 74HC595 Data
#define SHIFT_LATCH      PORTB.F0         // 74HC595 Latch
#define SHIFT_CLOCK      PORTB.F1         // 74HC595 Clock
#include "fnt.h"
char x,row,j,pos,i;
char buffer[40];
char msg[] = "Demotxt";
void main() {
   init();
   row = 0x01;
   j=0;
   pos=0;
   while (1){
      for (i=0; i<=39; ++i) {
         buffer[i] = font6x7[((msg[pos]-32)*6)+j];
         if (++j == 0x06) {
            j=0;
            pos++;
      for (i=0; i<=200; ++i) {
         for (x=0; x<=39; ++x) {
            SHIFT_DATA = 1;
            if (buffer[x] & row) SHIFT_DATA = 0;
            SHIFT_CLOCK = 1;
            SHIFT_CLOCK = 0;
         SHIFT_LATCH = 1;
         SHIFT_LATCH = 0;
         portc = ~row;
         row <<= 1;
         if (row == 0x80) row = 0x01;
         delay_us(1100);
         portc = 0xff;
   pos=0;
   j=0;
Fonts definitions are in one dimmension array:
const unsigned short font6x7[] = {
        0x00, 0x00, 0x00, 0x00, 0x00, 0x00,      // Code for char
        0x00, 0x00, 0x7D, 0x00, 0x00, 0x00,      // Code for char !
        0x00, 0x60, 0x00, 0x60, 0x00, 0x00,      // Code for char "
Can you give me idea how to solve this?
Regards
Refik Zaimovic
I found out one solution using constant char table
const char random_table[] = {0x00,0x00,0x00,0x00,0x00,0x00,
                             0x80,0x40,0x10,0x08,0x40,0x20,
                             0x88,0x48,0x18,0x0A,0x60,0x28,
                             0xC8,0x68,0x1C,0x4A,0x68,0x2A,
                             0xCA,0x69,0x5C,0x5A,0x69,0x3A,
                             0xDA,0x6D,0x5D,0xDA,0x6B,0xBA,
                             0xDE,0xED,0x5F,0xFA,0xEB,0xBB,
                             0xFE,0xEF,0x7F,0xFE,0xFB,0xBF,
                             0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
and then prepare buffer like this:
         //test1 = ((msg[pos]-32)*6)+j;
         buffer[i] &= random_table[j+tempj];
         if (++j == 0x06) {
            j=0;
            pos++;
With random_table stored in internal eeprom, 57 program words is saved.
You can generate random number in some different ways.
One of them is to use ADC of your uC with pin FLOATING, take the ADC reading and use it for your SEED for RND function.
Can you explain me what is pin floating?
I did try to use rnd function, but cant be sure that dots that are on at the one moment do not turn off in the next call of rnd.
I have another question. How to rotate one character for 90°, 180° and 270°?
