mdtanvir100
Newbie level 3
Hi there,
I am trying to simulate mismatch in a 10 bit D/A converter and unfortunately my PDK does not support Monte Carlo Simulation.
At least to simulate the threshold voltage mismatch I am trying to create a voltage source or a set of voltage sources which will generate random voltage each time I run the transient simulation in Cadence Spectre ADE.
Then I can connect the bias node to the random dc source and then to the gate of the current source to observe the threshold voltage effect.
It is a bit urgent for me to come up with the idea to do this. It would be great if you could advice me how can I do this in Cadence or by using Verilog A?
Regards,
Tanvir
Regards,
Tanvir
