RAM: rising edge detection not working
goodpranoy
Junior Member level 3
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity ram_ent is
port(addr:in std_logic_vector(3 downto 0);
    addr_in:in std_logic_vector(3 downto 0);
    data_in:in std_logic_vector(7 downto 0);
    ram_write:in std_logic;
    enter:in std_logic;
clock:in std_logic;
ram_enable:in std_logic;
dout:out std_logic_vector(7 downto 0));
end ram_ent;
architecture ram_arch of ram_ent is
type ram_arr is array(0 to 15)of std_logic_vector(7 downto 0);
signal tmp_ram:ram_arr;
begin
process(clock,ram_enable,ram_write,enter)
begin
  if  ram_enable='1' and ram_write='0' then
if (clock'event and clock='1') then
dout<=tmp_ram(conv_integer(addr));
end if;
elsif ram_enable='1' and ram_write='1' then
if rising_edge(enter) then
tmp_ram(conv_integer(addr_in))<=data_in;
end if;
end if;
end if;
end process;
end ram_arch;
i wanted the data to be written to the ram only when there is a rising edge from the enter pin.( i've planned to use a push button ).
but when i simulated in modelsim, then it is not working as planned.
can anyone please tell me what is wrong in the program and also how to correct it.
thanks in advance.
All code should be inside the clocked part of the process, otherwise it is not a true clock enable. To do edge detection, you need to register the signal, and then compare this registered version to the new one.
sir isn't it so in the given program?
what all should be given inside?
sir, i didn't understand the next part.
can we use enter'event and enter='1' as we do for clock enable on rising edge?
You can only use one rising edge detect, as this becomes the clock input to the infered registers. Registers in FPGAs can only work on a single clock edge.
k
so what should i do, if i want to write to RAM only at the rising edge of ENTER ?
register the enter signal, then check this register to the incoming version:
if rising_edge(clk) then
  enter_r <= enter;
  if enter = '1' and enter_r = '0' then --rising edge on enter
    --write to memory
