RAM not working as needed in spartan 3
goodpranoy
Junior Member level 3
hi guys,
i've used this code as a ram block in Spartan 3. But it was not
working.
i checked the RTL view of the file, but in that the RAM block have 2
pins unassigned(ENA and RSTA).
is that the problem why this is not working?
also the RAM created is a dual port RAM. I need only a single port RAM.
please help.
thanks in advance.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
entity ram_example is
port (Clk : in std_logic;
        address : in std_logic_vector(3 downto 0);
        we : in std_logic;
        ram_enable:in std_logic;
        data_i : in std_logic_vector(7 downto 0);
        data_o : out std_logic_vector(7 downto 0);
        enter:in std_logic
end ram_example;
architecture Behavioral of ram_example is
--Declaration of type and signal of a 256 element RAM
--with each element being 8 bit wide.
type ram_t is array (0 to 15) of std_logic_vector(7 downto 0);
signal ram : ram_t := (others => (others => 'Z'));
begin
--process for read and write operation.
PROCESS(Clk)
BEGIN
    if(rising_edge(Clk)) then
        if(ram_enable='1')then
        if(we='1') then
            if(enter='1') then
            ram(conv_integer(address)) <= data_i;
        end if;
            data_o <= "ZZZZZZZZ";
        elsif (we='0') then
        data_o <= ram(conv_integer(address));
        else
    end if;
end if;
--else
--data_o <= "ZZZZZZZZ";
end if;
END PROCESS;
end Behavioral;
You might get better results if you actually use the Xilinx IP tools to generate your RAM, rather than hoping it gets properly inferred. You've actually created an array of registers, which, in fact, sort of look like a dual port RAM they way you've created it.
