hiral.kotak
Full Member level 2
stil dft
HI,
These are the line, I got in the protocol file generated by DFT compiler. Can anyone explain the significant of W,V, C ...etc and regarding the syntax and value.
"load_unload" {
W "BROADSIDE_TIMING" ;
V {CLOCK=0; RESETB=1; SCAN_ENABLE=1; BIDI_DISABLE=1;
bidi_ports = \r16 Z;}
V {}
V { bidi_ports = \r4 1010 ; }
Shift {
W "SHIFT_TIMING" ;
V { _si=####; _so=####; CLOCK=P;}
V { CLOCK=0; RESETB=1; SCAN_ENABLE=0;}
} // end load_unload
} //end procedures
Thanks..
HAK..
HI,
"load_unload" {
V {}
Shift {
W "SHIFT_TIMING" ;
} //end procedures
Thanks..
HAK..
