Questions regarding LDMOS use and another question about "meaning of Short IO"
alex2013
Junior Member level 2
Questions regarding LDMOS use and another question about meaning of "Short IO"
I have 2 unrelated questions I hope someone can help me with:
1. I've never use a LDMOS. Is it just like a standard MOS but with higher breackdown voltages?
In fact I've never seen its schematic symbol. Is it just like a 4 pin MOSFET (source, drain, gate and backgate)?
If I intend to use this in an LDO (for the PMOS pass transistor and for the OPAMP), what kind of problem can be expected?
Can we use LDMOS in a similar circuit topology as a normal MOS?
I know LDMOS can be used with high supply voltage, but how about a low supply voltage?
If an LDMOS is said to have "Vrated |drain 12V", I assume this means that it can work with a 12V supply voltage. My question is can it usually work with "standard" supply voltage, like 3.3V (in a 180nm process)?
How much is the typical threshold voltage of an LDMOS?
I intend to use it in an LDO which should work with a high input voltage but also usable with low input voltage (input voltage from aroudn 3V to as high as possible).
2. What is the definition of a "Short IO"?
This is from a list of IPs provided by a foundry.
The full phrases is: "RVT 1.8V and 1.8V/5V short IO" and "Short true 5V IO"
Can anyone tell me what do these mean? What is "RVT"? is it Regular Threshold Volgate?
Sorry, I have too many questions :).
Thank you in advance :).
Re: Questions regarding LDMOS use and another question about meaning of "Short IO"
1a) ... LDMOS. Is it just like a standard MOS but with higher breackdown voltages?
Yes, but (usually) also with longer Lmin, thicker gate oxide, larger Vth and smaller gm .
1b) In fact I've never seen its schematic symbol. Is it just like a 4 pin MOSFET (source, drain, gate and backgate)?
Yes.
1c) If I intend to use this in an LDO (for the PMOS pass transistor and for the OPAMP), what kind of problem can be expected?
See 1a)
1d) Can we use LDMOS in a similar circuit topology as a normal MOS?
Re. schematic, yes.
1e) I know LDMOS can be used with high supply voltage, but how about a low supply voltage?
Yes. But larger area consumption than a standard MOS for comparable electrical values (re. current, gm).
1f) How much is the typical threshold voltage of an LDMOS?
Depends on gate oxide thickness. For a 5V gate oxide, e.g., Vth of a PLDMOS is between -0.6 and -1V .
Reactions: alex2013
    V
