iclayout1001
Newbie level 5
hercules nettran
Is there an command option of nettran to add a prefix"X" to the instance name when translating a hercules netlist to spice? And how to remove the string"u" of the parameters? If without such options, I will have to write a script to modify the converted netlist.
For example, my source hercules netlist like this:
{ inst r1 = rpply
{ prop w=0.9 l=8.0 rval=1455.0 }
{ pin net28=A net26=B vss=BULK }
When running with the following options,
nettran -hercules block1.herc -outType spice -outName block1.cdl
I got the netlist like this:
r1 net28 net26 rpply rval=8116.0 l=70.0u w=1.4u $BULK=vss
But I would like to the converted netlist like this:
Xr1 net28 net26 rpply rval=8116.0 l=70.0 w=1.4 $BULK=vss
{ inst r1 = rpply
