grit_fire
Member level 5
- Joined
- Mar 13, 2011
- Messages
- 82
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- USA
- Activity points
- 1,966
Hello, I have two questions related to input common mode voltage.
I understand that for an fully differential op amp, the two input signals are usually V1=Vcm+Vid/2 and V2=Vcm-Vid/2. In this case, Vcm (the input common mode voltage) is defined as (V1+V2)/2, which equals to Vcm. However, when there is only one single-ended input V1 and the other input V2 is grounded, assume no feedback, then if the Vcm is still defined as (V1+V2)/2 then it becomes V1/2. Does it make sense? For example, when ground V2, and V1=sin(wt). By intuition, I think the common mode input should be 0 volt (the DC offset of V1). Is that correct? But then it doesn't equal to V1/2.
Another question is: in some component datasheet (I am looking at LT6044-15, whose common mode input range is from 0 to 1.5 V at 3V supply voltage), it usually specifies the common mode input range. I have been thinking: does this spec make sense? If the DC offset for V1 is super high (100V) and V2 is super low (-100V), the op amp surely won't work, but by definition, Vcm=(V1+V2)/2=0V, which is still within the allowed range. Isn't this weird? Unless this spec refers to one terminal, i.e. the DC offset of one terminal. How should I understand the dilemma here?
Thanks a lot!
Thanks a lot!
