movie_freak
Member level 5
p channel mosfet switch
I am confused regarding the working of mosfet for switching:
till now what i completely understand is:
Case 1:
https://www.physics.udel.edu/~watson/scen103/mos4.html
Case 2:
https://www.physics.udel.edu/~watson/scen103/mos5.html
From above case two is in low-side switch configuration and case one is in high-side.
I thought that n-channel is used as high-side switch and p-channel for low-side switch..
but i later found out on google that n-channel can also be used for low-side and p-channel for high-side. This created confusions and questions..
Guys pls bare with me.. my questions can be silly cause i don't have much knowledge regarding this..
here they go:
--> Is it true that p/n type can work in both high/low configuration..
--> If both can work in both configurations why do we have two seperate mosfets..
(if this is the case the only difference that i know is the resistance provided)
--> Is there any changes or certain elements that needs to be added to a particular p/n type to work in certain high/low configuration or nothing matter any mosfet can be used in any configuration as it is..
--> Why do we need a drive to work Mosfets in H-Bridge configuration, otherwise i saw my mosfet's being burnt..
Many Thanks,
Surya
Case 1:
Case 2:
here they go:
Many Thanks,
Surya
