questions about "CDS_Netlisting_Mode" (IC5.0.0)
worst
Newbie level 6
Shanghai,China
cds_netlisting_mode
I have some questions about using IC5.0.0.
When I run a trans simulation in AE(the circuit include a pluse voltage supplier),I
get a error message:"Error found by spectre during hierarchy flattening. V1: Waveform type must be specified if any waveform paras are given."
Somebody tell me this is because I set the CDS_Netlisting_Mode wrong.But I have set ".bashrc" as the article "Cadence IC Linux Installation Tutorial v0.1 - 01.05.2005 ".
The following is my ".bashrc":
CDSDIR=/IC5
CDS_ROOT=/IC5
CDS_INST_DIR=/IC5
CDS_INSTALL_DIR=/IC5/tools/dfII
export PATH =$CDSDIR $CDS_ROOT/tools/bin $CDS_ROOT/tools/spectre/bin:$PATH
export PATH= ( $path $CDS_INSTALL_DIR/bin )
export CDS_Netlisting_Mode "Analog"
export CDS_Netlisting_Node "Analog"
export CDS_LIC_FILE=/usr/local/flexlm/license.dat
I couldn't sure which is right "CDS_Netlisting_Mode" or "CDS_Netlisting_Node", so I write them two.
Anybody can help me check the ".bashrc" file and tell me why the problem will be
exist?
Thank you very much!
cds_netlisting_mode analog
The variable name is CDS_Netlisting_Mode.
Some statements are wrong:
should be:
export PATH=$CDSDIR:$CDS_ROOT/tools/bin:$CDS_ROOT/tools/spectre/bin:$PATH
export $PATH=${PATH}:$CDS_INSTALL_DIR/bin
export CDS_Netlisting_Mode="Analog"
Use ":" as the delimiter for paths.
Environment variable assignment needs a "=" sign.
export path=$cds_root/tools/bin
should be:
First,Thank you very much for your kindness:>
I'm not familiar with the Linux, and so i modify the .bashrc as your said.
But, unfortunately the error is also exist.
This is my ".bashrc" now:
CDSDIR=/IC5
CDS_ROOT=/IC5
CDS_INST_DIR=/IC5
export PATH =$CDSDIR:$CDS_ROOT/tools/bin:$CDS_ROOT/tools/spectre/bin:$PATH
export PATH= $path $CDS_INSTALL_DIR/bin
As I know, the problem looks like the CDS_Netlisting_Mode is not set rightly.But it is set now.How can I check it?
Or perhaps is the problem cause by the license line?
how to set the cd netlisting mode to analog
I am not sure the problem is related with CDS_Netlisting_Mode environment variable. If this variable is not set, IC 5.0.32 can set it automatically. But I don't know whether IC5.0.0 is so clever.
But the statement setting CDS_Netlisting_Mode in .bashrc is correct:
or
export CDS_Netlisting_Mode=Analog
Both are correct.
You can run in Cadence CIW:
getShellEnvVar("CDS_Netlisting_Mode")
to view the results.
It may be a bug, but I am not sure either.
17: cds_root: not found
Hi!
Thanks again.
I have use the command "getShellEnvVar("CDS_Netlisting_Mode")" to check, the result is "Analog".So it means the CDS_Netlisting_Mode set is right.
Or it's a bug of 5.0.0?
Maybe the problem is because the license?Can you tell me how to check the license state?
what is cds netlisting mode?
I think it is a well-know bug of IC50. This bug has been fixed in the following USR and hot fix. You should update your IC first.
cds_netlisting_mode
From CIW's main menu, select "Options / Licenses...". You will see available licenses.
export cds_netlisting_mode
1 In IC5033 and running bash (.bashrc) you have to type
CDS_NETLISTING_MODE="Analog"
in caps
(without caps) would produce a "nil" when you
3 You also get a "nil" if you do
getShellEnvVar("CDS_NETLISTING_MODE")
after doing step 1 above, so use
after step 1 to test in the icw shell
cdsdir & cds_root & cds_inst_dir
In your last correcting post, this is still FORMAT error. Fix it!
cds_netlisting_mode
I have the same question with the poster. But my cadence version is IC5141(sub_version : 5.10.41.169)
Would you please clearly advise me how to solve this problem? I have stuck at this quesion for one whole day.
thanks.
