arsenal
Full Member level 2
hi,
As to buck DC-DC converter from 12v to 3.3v,
1. in synchronous rectification, some use MOSFET with the body diode integrated instead of the external diode, then how is this body diode integrated?
2. The 12V input voltage has to be scaled down to act as the power for the controller, then how to scale it down? by resistors? If so, will it affect the efficiency?
3. As to the saw-tooth pwm, is it generated by some oscillator with an integrator?
thanks
arsenal
thanks
arsenal
