I'm new to HFSS. For simulating planar dipole RFID antenna using HFSS, I noticed that lumped port is used usually, and the lumped port impedance is set to the conjugate value of the chip impedance.
My question is:
Because RFID antenna is directly connected to the tag chip for cost down, then the impedance of the antenna should be conjugate matched with the tag chip impedance. If the lumped port impedance is already set to the conjugate value of the tag chip impedance, then how I can check from the HFSS simulation result that the antenna is really matched with the chip impedance, instead of matching by manually setting the lumped port impedance?
Thanks in advance!
