[SOLVED] question on vcs -f filelist ?
sxlwzl
my fold contain these files:
top.sv
dpi.h
dpi.cc
I do vcs command like this :
vcs -sverilog top.sv dpi.c -R
The result is ok.
But when use file list options like this:
vcs -sverilog -f filelist -R
$cat filelist
top.sv
dpi.h
dpi.cc
the result is wrong.
can any body help me about this question, thanks.
What was the error message?
thanks.
APMO, -f is used for pnly verilog files, u can not define .cc file in filelist.
So please try following :
vcs -sverilog -f filelist dpi.cc -R.
Please let me know if solved or not.
Regards,
Maulin Sheth
thanks.
here is the wrong message.
Regards,
Maulin Sheth
the method you provide can solve the problem.
but when i have too many cc file, this way do not a good solution.
can you find out another way that can include cc file in filelist. thanks.
Can I know what the content of your .cc file, what is the purpose of that .cc file in simulation?
Regards,
Maulin Sheth
Regards,
Maulin Sheth
print.h
#include <stdio.h>
extern "C" {
    void c_print();
print.cc
#include "print.h"
void c_print(){
	printf("c_print\n");
top.sv
module top;
import "DPI-C" function void c_print();
initial
begin
	$display("sv_print.");
	c_print();
end
endmodule
I just want to know how to add cc files to vcs, because many model is writed by cc.
Here is one way to do it:
1) Compile your C code with GCC or G++
2) Next, if the C code was compiled with x86_64 bit. Thus, to make it VCS simulator compatible with the generated C library file (*.o, *.so) use this line of command:
vcs -full64 -sverilog -R +define+VCD -f ../../sim/filelist.f clk_xactor.o
Hope it helps.
-no_mad
Hi no_mad,
I see you post a article at https://www.edaboard.com/threads/206597/
thanks your sharing.
sxlwzl
Hope it helps.
-no_mad
