Question on unused LM3915 pins
graygem
Member level 1
Member level 1
Just a quick question on what to do with the unused LED pins on a LM3915. I'm only using 3 of the 10 LEDs. What do I do with the other 7 pins? Ground or nothing??
Thanks
Each output of an LM3915 is an open collector that sinks a regulated current when it has an LED or resistor as a load connected to the positive power supply. If an output does not have a load then the output does nothing and does not need to be connected to ground.
Reactions: d123
    d123
Thank you. That is what I thought but just wanted the second and third opinion. :grin:
LaTeX Commands Quick-Menu:
