Question of pulse width doubler
bhl777
Full Member level 6
Hi all, if I have a randomly generated pulses (duty cycle <50%) as the input, how can I use simple logic circuit to generate an output pulse, whose pulse width is twice of that of the input pulse? Thank you! pulse width doubler.png
What is the minimum time between the falling edge of the one pulse to the rising edge of the following pulse?
What frequency or repetition rate is involved?
the frequency is typically around 300kHz to 600kHz, and duty cycle is less than 50%. So there is no problem of the overlap between the doubled pulse and the rising of the next cycle. Thank you!
The feasibility of this depends on the range of pulse widths.
But how about an up/down counter that counts up during the pulse duration, then counts back down ?
This is going to take more than a bit of "simple" logic.
How accurate does the "twice" have to be and what resolution is required?
That will determine the circuit complexity required.
It certainly won't be "simple".
Would you teach me how to do it? The pulse width will be around 300ns and above, not necessarily exact twice.
The pulse width will be around 300ns and above, not necessarily exact twice. Would you teach me how to do it?
300nS is too fast for the up/down counter approach.
If it was 300mS or even 300 uS it might have been possible.
Can you explain more about the application you need this for and why? That will give all of us a better idea what you are trying to do.
I was thinking about a bidirectional current source charging/discharging a capacitor with a comparator that trips near the zero point, but that may be too slow as well. This way the you get double the pulse width with a small error.
Reactions: bhl777
    bhl777
A simple DCR arrangement works (approximately) if duty cycle is short. The capacitor and potentiometer values are determined by experimentation. The aim is to adjust capacitor charge/discharge so it goes above 2.5 V for a portion of the cycle which is proportionate to pulse length.
Reactions: bhl777
    bhl777
This would be also my solution. An accuracy of e.g. 1 % of the pulse period (about 20 ns) should be achievable with regular analog design, even ns range with really fast components. On the other hand, 5 or 10 ns ís no problem with standard programmable logic, could think of a single chip solution with a recent flash based FPGA.
The capacitor charge/discharge most stay in a small (approximately) linear part of the exponential curve. Otherwise the intended fixed pulse width relation can't be achieved. It's better to use current sources.
Reactions: bhl777
    bhl777
Below is the LTspice simulation of an analog pulse stretcher circuit.
It uses two complementary constant-current-mirrors and a fast comparator.
The two current mirrors are alternately turned on and off by the input signal.
The transistors must be fast switching types, otherwise saturation delays can be a problem.
The circuit inverts the input so there needs to be an inverter added at the input if that is not desired.
Pot U2 adjusts the pulse width to be twice the input width.
The simulation is shown for input widths of 300ns and 1.5µs, giving output widths of ≈ 600ns and 3µs.
Just noticed a couple of typos in my #11 thread and I can't correct them because of the annoying and odd time limitation on editing ones own threads on this site (which the other two sites I frequent don't have. :-?
But anyway, the second line should be:
and the second to last line should be:
The simulation is shown for input widths of 300ns and 1.5µs,...
