Sinusoidals are the aigen functions of linear system. You can calculate the system response to them easily.
Using fourier theorom you can write many of practical signals in terms of sinusoidals. And your response is the sum of individual responses to these terms.
Sine waves are used because in liner circuits the effect on them can be only phase variation and hence the signal isn't distorted
regarding system response sine waves are not optimal for that but delta function is
This wave is used, because the sine wave is a particular case of the complex exponetial funtion, and for the Fourier Analysis you can see that the sine wave is the funtion basics of the Fourier Series and this make the analyisis of the systems easily.
