Question about Power Added Efficiency for Class E power amplifier
sharethewell
Member level 5
We all know that power added efficiency is defined as:
PAE=(Pout-Pin)/Pdc
Does Pdc here only means Power supply Power? What if the biasing terminal in the circuit also consumes some power? Is this included in the Pdc as well?
The Pdc here should include all the power supplies if there are separated digital power supply and analog power supply, right?
Thanks a lot!
pancho_hideboo
Advanced Member level 5
Real Homeless
Usually I include this.
Usually I exclude dc_power for DVdd.
I include dc_power for only AVdd.
vfone
Theoretically you don't have to include the digital power supply, but if you are a System Design Engineer you have to include.
This mostly to see how the PA efficiency affect the entire system.
To check the efficiency of the PA sometimes is enough just finding the DC to RF efficiency. PAeff = PA_RFout / Pdc
sharethewell
Member level 5
So the Pdc in the equation includes power consumption of the biasing terminal in the circuit, right? I just found that the biasing power consumption is almost the same as the input power, which is about 2 mW.
vfone
Yes, the bias power could be comparable to input power.
Bias power consumption is part of Pdc, but usually is much lower than collector/drain DC power, which is the main contributor for Pdc.
