Question about PIC16F887 programming/programmers
deepmak
Member level 2
Member level 2
Good day all
im working on a control circuit that i plan to use PIC16F887 as controller , i plan to use all possible I/Os (35 +1 RE3 as input as well ), and im using MikroC as IDE, from my humble understanding , using LVP will make me lose one pin , is that correct ? and will i be able to use only Higher voltage programming ? most of universal programmers that i can access support 3.3 to 6.5 volts devices , any suggestions ?
another question , to use RE3 as input , i should set RE3/MCLR option to "Disabled " ?
thanks in advance
Regards
Thanks for the quick response , i will check the link and other info available
for the second question , is my assumption correct ?
thanks again
Regards
