Question about opamp type?
samy555
Full Member level 4
Full Member level 4
Palestine
Hi
For the following circuit from:
https://electronics.stackexchange.com/questions/42923/what-do-i-need-for-a-basic-rf-circuit
I have 3 questions:
(1) Is LM311 is suitable fOr IC1 a & b?
(2) Why D1 & D2?
(3) What the function of the subcircuit consist of IC1b, R15 and D3?
thanks alot
1. the ICs have to amplify the data, so depends on your data rate - should be OK see :- **broken link removed**
2. D1 stabilised the DC operating conditions, D2 stabilises the squegging amplitude.
3. R15 +C10 are a peak detector so the comparator fires the output while the capacitor charges on positive peaks, R14 roughly charges C10 up at the same rate as its leakage current would discharge it, an example is shown in the data sheet.
Frank
How and why?
What is the squegging amplitude? I have not heard of it before!
Is roughly charges = slowly charges?
Is that leakage current because C10 is electrolytic cap?
I understood that the signal output from IC1a charges C10 through R15 (when +ve peak) and at the same time battery charges C10 through R14 to compensate for the lost charge (leakage current),,, Is that true?
What is the role of the diode D3 here?
Thank you Frank
2. The voltage drop across D1 matches the volt drop across the Vbe of the transistor. This receiver is a super-regenerative type. Note the "super" is short for super sonic. the transistor actually oscillate at a supersonic frequency, which should be a lot higher then the data or channel bandwidth and a lot lower then the frequency its actually meant to use. The effect of this oscillation - called "squegging", is that the actual tuned circuits have positive feed back across them for part of the squegging cycle, this raises their Q and hence their sensitivity by a factor of 100 or so. In the old days the level was set manually and if mal-adjusted ,various howls and whistles would emerge from the radios loudspeaker, coupled with interferrence to adjacent radio users. :)
Frank
Can't get to your circuit now, link going to a different site?
