jeffreycheng
Junior Member level 2
momentum post process
When I use the post-processing visualizaton to check the current ditribution of a spiral inductor. The figure only show several discreted highlight triangles along the trace. But for another spiral inductor which is litter bigger it can clearly show the coutinuous highlight currents crowding at the inner side of the spiral.
Is there any possibility for the post processing failed to showed the exact currents?Beacause the S parameter results seems has no problems. Thank you.
