Question about mentor IC flow and Calibre integration
ofdm_papr
Junior Member level 2
install icflow
I have installed the Mentor IC flow 2006 under /opt/mgc_tree/2006.1_rhelx86linux/icflow_home, & later try to install Calibre 2005 under the same directory. But my source program is a self-extraction one that it will automatically creat a ixl_ca_2005.4 directory under the previous mentor directory. So the two softwares are not integrated at all because only one $MGC_HOME can be specified. How can I solve this problem?Should I need to copy all the stuff and create the link manually?
calibre mentor
Use the script "calibre_icflow_install" that is inside the calibre directory, run it without parameters to get the help text.
    ofdm_papr
rhel for calibre
But I can not find the exact location of the script from my ixl_cal_2005.4_14.18. Any suggestions?
Added after 7 minutes:
I also found some note from the mentor installation guide. My system is RHEL AS 3.It seems it does not support the integration at all:
The calibre_icflow_install script does not support installing a Calibre tree on top of an IC
Flow tree on RHEL 3 or SLES 8. This script should not be used to install a Linux Calibre
tree on top of an IC Flow tree if running on the RHEL 3 or SLES 8 operating systems.
Installing a combined Calibre and IC Flow tree on RHEL 3 or SLES8 is not supported,
nor recommended.
