mannokhkhkhk2207
Newbie level 3
- Joined
- Jan 8, 2015
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 44
Firstly, sorry for my poor English and I know that this is a idiot question in electronic. I am a fresh beginner.
1st question, Imagine that I have a portable battery which can output 5v/2A. What does it means? Is it means this battery will force itself to output 5v with 2A? Or just means this battery will output 5 volt and can provide 2 amp at maximum?
2nd question, for those AA battery in the market state that they can output 1.5v but they doesn't stated the output current. Then what is the current they output? Assume I have a LED which consume 3v to light up, then I connect 2 1.5v battery to become 3v and supply power for the LED. Then what is the current in the circuit? Is the resistance of the LED constant? Why the LED won't blew up? << (I have tried, the LED work perfectly)
3rd question, I want to buy a motor that consume 1 - 6v and the reference current is 0.35-0.4A. What is the meaning of reference current? Is it means that the motor will regulate the current pass through itself to 0.35-0.4A? If I supply the power to the motor by the portable battery stated in 1st question (output 5V/2A), will the motor blew up because of the current supply (2A) is much larger than the reference working current stated by the motor (0.4A)?
4th question, I have a device that should be powered by 5v/1.2A via micro USB. Will I damage the device if I use 1st question portable battery as power source? If no, what is the current output by the battery? If the current is 1.2A then is it means the device can regulate the circuit current to 1.2A even the power source can output 2A? If the answer is YES, how about I change another power source that output 10A? Will the device be damaged? (because I have tried to supply power to a LED by a laboratory DC power supply, I keep increasing the supply current, the LED blew up finally.)
Sorry for those long questions, I am a newbie. I know the basic theory of KCL, KVL and ohms law, it will be appreciated if anyone can explain the answer to me by these laws.
Thousand Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:thumbsup:
