How do we find the model parameters of a particular design kit in cadence?
For example, what commands or menus should I choose to find the model parameters of TSMC 0.18 micron technology design kit?
these messages indicate the model file and used corner
mm018.scs is the model file, and section=tt is the specified section
you can look into this file through edit it
How can I figure out Lambda an UCox...plz let me know....
Added after 6 minutes:
Hey Gingerjiang
in my cadence version(5.1.4.1), i look into the model file through Edit File button, but your cadence edition is differ from mine, so i don't know if yours has this button or menu instruction
it's no matter, however, you can access to /opt/local/cadence/design_kits/TSMC/tsmc018/models and vi mm018.scs
about lambda, cox..., you can get the answers from the model file directly or indirectly
good luck
