I assume you are looking to suppress the noise that comes on the DC bias lines.
You didn't mention if is about a low power, medium power, or high power circuit.
If is about a low power circuit is enough to use RC filter on the drain/collector bias and also an RC filter on the gate/base bias supply. This would give an efficient wideband noise filtering.
If is about a power amplifier things are a bit more complicated, because any resistors placed on the above lines will affect the amplifier linearity, so you have to use a combination of RLC filters.
