Sorry guys for such long respond, i had some stuff that i have to end...
OK.
This is the idea that i want to use:
Windturbine rotor -> transaction wheel gear -> 55 Amps alternator -> AC output
As you can see there is no battery after alternator.
This is partly because this is just test and because i want to avoid the use of battery in the future. I dont need constant power ( for now ) and for start an satisfied with low power output
. I dont want to use the DC and if am correct i can use the AC from the alternator.
Question is, how much AC output power, at 70 turns/min, can be produced from 55Amp alternator ?.
Max
p.s. if you need additional details, please write down...
