Can anyone tell me about this warning
when i typed this command to clear this violation its giving this kind of warning setClockDomains -from reg -to reg
1000ns will be added excluding this path why ?
i have seen the report also but its not adding
any reason for this
May be i am wrong, I did not understand is that u want to add 1000 ns . But from teh manual wat i learned is u can design a clock bte reg to reg or there are options. this is based on my knowledge is to get timing report.
see my question is if u want to remove the violation for reg to reg path then we have to specify the clock domains right?
when i specified
setclockDomains -from type reg -to type reg
i got this warning
1000ns will be added for slack adjustments that is for other paths but not for reg to reg path...
take care i hope u understand this statement
u also plz try in encounter and see for any project but for a block
take care
May be its just me, but I don't understand the question. What tool are you using and what are you trying to do? Why do you have to specify clock domains?
i am also getting the same statement wt do u mean by this
paths not in the reg to reg paths are added 1000ns
so wt do u mean by that
Bye take care
Added after 2 minutes:
iwpia50s tell me one thing if i want to remove the violation for a reg to reg path then wt shd i do?
i have to set the clock domain first then i need to remove the violation...i am giving the chance to the tool by giving this
setClockdomains -from reg -to type reg
then optimize that path only
got it
iam also getting this in soc encounter tool too
bye take care
Based on the Encounter documentation you set clock domains if you want to optimize a specific clock domain. If you don't specify any, then Encounter optimizes all clock domains. If you have a CDC path then specifying a clock domain to optimize could break the timing on that path.
