questin in fully op amp ?
wael_wael
Full Member level 4
hi every body
i have 2 stages fully differential op amp, i want increase the current in second stage. in fact when i increase the current in the bias circuit the current in first stage increase but in second stage not increase much . so could some one help me and give me any idea to increase the current in second stage
thanx
just few thoughts up in my head.
1) test each stage separately. say, only work on your 2nd stage and see if increasing the current in your bias ckt changes anything in your main ckt.
2) i think it's a little hard to help you w/o your schematic. can you upload ur schematic?
cheers
    wael_wael
separate bias
Check the second stage's input bias point.
    wael_wael
If you use current mirror, then change the W/L of the current mirror in the sencond stage. The current bias circuit should not change. I think.
Ryan
    wael_wael
