riz1679
Newbie level 3
I am trying to simulate some design. The pre-scalar in the design was working fine with the top level test bench. now I have instantiated another block in the test bench which configure the prescalar but pre-scalar generates a fatal error during simulation. When I try to load the counter value in the prescaler register it loads the value but suddenly gives a fatal error and again go back to value zero..
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 ------------------------------------------------------------------------------- -- CANAKARI CAN Modell -- Diplomarbeit ------------------------------------------------------------------------------- -- Der Prescaler teilt den 10 MHz Eingangstakt herunter: ------------------------------------------------------------------------------- -- DW 2005.06.21 Prescale Enable eingefügt -- DW 2005.06.26 Prescale Enable korregiert LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_misc.ALL; USE ieee.std_logic_arith.ALL; USE ieee.std_logic_signed.ALL; ENTITY prescale1 IS PORT ( clock : IN bit; reset : IN bit; high : IN bit_vector(3 DOWNTO 0); -- IOCPU, prescaleregister low : IN bit_vector(3 DOWNTO 0); -- IOCPU, prescaleregister Prescale_EN : OUT bit; -- DW 2005.06.21 Prescale Enable clock_low : OUT bit); END prescale1; ------------------------------------------------------------------------------- ARCHITECTURE behv OF prescale1 IS SIGNAL lo_count, hi_count : integer RANGE 0 TO 15; SIGNAL hilo : bit; -- hi=1 , lo=0, Merker für akt, Flanke SIGNAL int_high, int_low : integer RANGE 0 TO 15; ------------------------------------------------------------------------------- BEGIN -- behv clock_low <= hilo; -- = Merker für Flanke -- Konvertierungen für Vergleich int_high <= conv_integer(unsigned(to_stdLogicVector(high))); -- bit_v zu int int_low <= conv_integer(unsigned(to_stdLogicVector(low))); ------------------------------------------------------------------------------- teil : PROCESS (clock, reset) BEGIN -- PROCESS teil IF reset = '0' THEN -- asynchroner Reset lo_count <= 0; hi_count <= 0; hilo <= '1'; Prescale_EN <= '0'; -- DW 2005.06.21 Prescale Enable ELSIF (clock'event AND clock = '1') THEN ------------------------------------------------------------------------- IF hilo = '1' THEN -- Positiv Flanke Prescale_EN <= '0'; -- DW 2005.06.21 Prescale Enable IF hi_count >= int_high then -- DW 2005.06.26 Übergang von hilo von -- 1 auf 0 Prescale_EN <= '0'; -- DW 2005.06.26 Prescale Enable hi_count <= 0; -- zurücksetzen hilo <= '0'; -- umschalten ELSE hi_count <= hi_count+1; -- inkrementieren END IF; ----------------------------------------------------------------------- ELSE -- Negative Flanke IF lo_count = int_low THEN lo_count <= 0; -- zurücksetzen hilo <= '1'; -- umschalten Prescale_EN <= '1'; -- DW 2005.06.26 Prescale Enable ELSE Prescale_EN <= '0'; -- DW 2005.06.21 Prescale Enable lo_count <= lo_count+1; -- inkrementieren END IF; ------------------------------------------------------------------------- END IF; END IF; END PROCESS teil; END behv;
