query on crystal replacements
onoffman
Member level 3
hi,
I am making an ARM9 board that needed the crystals as shown
1)
18.432Mhz pack:3.2x2.5 mm e.g. ABM8-18.432MHZ-B2-T
2)
25 Mhz pack :MM20SS e.g.ECS-.327-12.5-17-TR
3)
32.768Khz pack : 3.2x2.5 e.g.ABM8-25.000MHZ-B2-T
these were not available in local market and digikey etc costed 5-6 times more
My changes
>>I bought local crystals as shown
1)18.432Mhz pack thru hole **broken link removed**
used with : AT91rm9200 atmel arm9 chip
2) 25 Mhz http://uk.farnell.com/productimages/farnell/standard/GE2HC494HSMX06-40.jpg
used with : ethernet controller chip
3)32.768Khz
used with :AT91rm9200 atmel arm9 chip
>I can manage to stick the crystals with superglue to some part of pcb
and join small wires to smd pads.
Question is will the substitution work.
[/url]
As you have got the same values of the required components, it should work. It doesnt matter how you fit it...Cheers
Hi onoffman,
be care, that you will nothing connect_dont make shorts_ to some other potencial trough the metal can!
K.
pranam77, karesz
thank you ..
i have done lott board buiding, smd too
i wil not short or allow metal can to touch
But the original parts had 4 pins these have 2 ..
where to put the pf capacitors ?
Look at the datasheet of the 4 pin types: 2 pins are not connected, 2 pins are the crystal.
Connecting the 2 load caps to 2 pins of the crystal isn't too difficult :)
    onoffman
M!k,
that was a great help ! I will do that!
M!k said:
onoffman said:
...of the 4 pin types: 2 pins are not connected, 2 pins are the crystal...
Be care, they are some (newer) Xtals on the market, with top plate contacting to the told "not connected" pins:) _ or minimum to one of both.
Also, its possible, that the not Xtal pins are i.e. on GND, but the Xtal pins=so the capacitors are surly not on GND-they are guided to the IC...
K.
