Quality factor of inductor
promach
Why is R=QLw ? I suppose R=Lw/Q ?
There are two different R here
Series R (Rs) and Parallel R (Rp)
For Series R:
Rs= LW/Q
For Parallel R:
Rp=QLW
How you calculate Q for two component network, write this down somewhere:
Q= Imaginary (Z) / Real (Z) -----> For series
Q= Imaginary (Y) / Real (Y) -----> For parallel
In the example you mentioned it is talking about parallel R which is Rp
Don't look at the resonator math, because this is an inductor only, and we want to get the inductor Q. This is done by evaluating the impedance and interpret it as series RL. In this calculation, existing parasitics will be cause a frequency dependent L and frequency dependent R. Q factor is calculated from that L(f) and R(f).
Practical RFIC example with Q(f), L(f) and R(f):
@Ata_sa16 Could you shed more lights on these two statements above ?
I have found a simple explanation but "inductor stores energy half the time and releases the energy the other half."
Extracted from https://physics.stackexchange.com/a/109749
you have completely misunderstood the Q here. S=P+j*Q here Q is not the same Q
This Q is reactive power not quality factor.
Do you know complex power ? this is totally different topic.
As I mentioned in previous post. For now just forget about VCO and start reading about fundamental concepts like:
1) What is Quality factor? why it is important ? what is it relationship with Loss and Noise.
2) Quality Factor in two component networks (R-L and R-C series and parallel)
3) Quality factor in RLC resonant circuit (It is not the same Q as two component network)
Maybe this helps you
https://www.electrical4u.com/quality-factor-of-inductor-and-capacitor/
Then the maximum energy stored in the inductor is written in terms of current
For parallel R-L you may use similar approach but this time rewrite terms in terms of voltage you will reach my formulae
It is not really important and necessary to know where are they coming from all you need to know is 2 formulae I have provided
Rp=QLW = (10*1nH*10GHz) != 630
Do you know w=2*pi*f ??? 8-O
you put w=10 GHz !! :shock:
You need to learn/review fundamental concepts before designing VCO.
1.2K is Rp of 2 inductors, here for calculations we need half of the circuit. As it is written fig.8.18
You need to read the book carefully.
