lcd 16f877a ccs
Salam,
Here is a code in picbasic
' Set LCD Data port
DEFINE LCD_DREG PORTB
' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_DBIT 4
' Set LCD Register Select port
DEFINE LCD_RSREG PORTA
' Set LCD Register Select bit
DEFINE LCD_RSBIT 0
' Set LCD Enable port
DEFINE LCD_EREG PORTA
' Set LCD Enable bit
DEFINE LCD_EBIT 2
' Set LCD bus size (4 or 8 bits)
DEFINE LCD_BITS 4
' Set number of lines on LCD
DEFINE LCD_LINES 2
' Set command delay time in us
DEFINE LCD_COMMANDUS 2000
' Set data delay time in us
DEFINE LCD_DATAUS 50
PAUSE 30
LCDOUT $FE, $080
LCDOUT $FE, 1, " Hello " ' Clear display and show “Hello PIC”
LCDOUT $FE,$0C0, " PIC "
END
Hope that this could help u
