sunil_kasar
Newbie level 6
Hello All,
I am new to STM8AF MCU. I have configured TIM1 and TIM3 as PWM output channels. TIM2 channel 1 (PD4) as input channel. I am getting correct result when I look at PWMout result in CRO. Same PWM output of TIM1 channel1, I am feeding as input to TIM2 channel1(PD4) and sending over CAN. When I look at result in CAN it is throwing in valid data. I am not getting 50% of 4095 in CANalyzer. I am posting the code below. Please help me to get rid of this problem.
#define CCR1_Val ((uint16_t)2047)
#define CCR2_Val ((uint16_t)1535)
#define CCR3_Val ((uint16_t)1023)
#define CCR4_Val ((uint16_t)511)
#define CCR_MAX_VAL_100DC 4095
/* Private function prototypes -----------------------------------------------*/
static void TIM4_Config(void);
static void Delay(u32 nTime);
void TimingDelay_Decrement(void);
static void L99PM62drv_WdgAutoTrigger(u32 WdgAutoTriggerValue);
static void CLK_Config(void);
static void GPIO_Config(void);
void delay_ms(uint16_t msTime);
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
* @brief Configure TIM1 to generate 7 PWM signals with 4 different duty cycles
* @param None
* @retval None
static void TIM1_Config(void)
TIM1_DeInit();
/* Time Base configuration */
TIM1_Period = 4095
TIM1_Prescaler = 0
TIM1_CounterMode = TIM1_COUNTERMODE_UP
TIM1_RepetitionCounter = 0
TIM1_TimeBaseInit(0, TIM1_COUNTERMODE_UP, CCR_MAX_VAL_100DC, 0);
/* Channel 1, 2,3 and 4 Configuration in PWM mode */
TIM1_OCMode = TIM1_OCMODE_PWM2
TIM1_OutputState = TIM1_OUTPUTSTATE_ENABLE
TIM1_OutputNState = TIM1_OUTPUTNSTATE_ENABLE
TIM1_Pulse = CCR1_Val
TIM1_OCPolarity = TIM1_OCPOLARITY_LOW
TIM1_OCNPolarity = TIM1_OCNPOLARITY_HIGH
TIM1_OCIdleState = TIM1_OCIDLESTATE_SET
TIM1_OCNIdleState = TIM1_OCIDLESTATE_RESET
TIM1_OC1Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, TIM1_OUTPUTNSTATE_ENABLE,
CCR1_Val, TIM1_OCPOLARITY_LOW, TIM1_OCNPOLARITY_HIGH, TIM1_OCIDLESTATE_SET,
TIM1_OCNIDLESTATE_RESET);
/*TIM1_Pulse = CCR2_Val*/
TIM1_OC2Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, TIM1_OUTPUTNSTATE_ENABLE, CCR2_Val,
/*TIM1_Pulse = CCR3_Val*/
TIM1_OC3Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, TIM1_OUTPUTNSTATE_ENABLE,
CCR3_Val, TIM1_OCPOLARITY_LOW, TIM1_OCNPOLARITY_HIGH, TIM1_OCIDLESTATE_SET,
/*TIM1_Pulse = CCR4_Val*/
TIM1_OC4Init(TIM1_OCMODE_PWM2, TIM1_OUTPUTSTATE_ENABLE, CCR4_Val, TIM1_OCPOLARITY_LOW,
TIM1_OCIDLESTATE_SET);
/* TIM1 counter enable */
TIM1_Cmd(ENABLE);
/* TIM1 Main Output Enable */
TIM1_CtrlPWMOutputs(ENABLE);
static void TIM2_Config(void)
TIM2_ICInit( TIM2_CHANNEL_1, TIM2_ICPOLARITY_FALLING, TIM2_ICSELECTION_DIRECTTI,
TIM2_ICPSC_DIV8, 0x0);
/* Enable TIM2 */
TIM2_Cmd(ENABLE);
/* Clear CC1 Flag*/
TIM2_ClearFlag(TIM2_FLAG_CC1);
static void TIM3_Config(void)
TIM3_DeInit();
TIM3_Period = 4095
TIM3_Prescaler = 0
TIM3_TimeBaseInit(0, CCR_MAX_VAL_100DC);
TIM3_OCMODE = TIM3_OCMODE_PWM1
TIM3_OUTPUTSTATE = TIM3_OUTPUTSTATE_ENABLE
TIM3_Pulse = CCR2_Val
TIM3_OCPolarity = TIM3_OCPOLARITY_LOW
TIM3_OC1Init(TIM3_OCMODE_PWM1, TIM3_OUTPUTSTATE_ENABLE, CCR1_Val, TIM3_OCPOLARITY_LOW);
TIM3_ARRPreloadConfig(ENABLE);
/* TIM3 counter enable */
TIM3_Cmd(ENABLE);
uint16_t GetCountForDutyCycle(uint8_t dutyCycle)
return (((uint32_t)dutyCycle * CCR_MAX_VAL_100DC)/100);
uint16_t PWMInput2_u16;
uint16_t PWMInput1_u16;
uint16_t LSIClkFreq;
void main(void)
TIM1_Config();
TIM2_Config();
TIM3_Config();
L99PM62drv_RegType reg;
/* GPIO Configuration ---------------------------------------*/
//GPIO_Config();
/* CAN */
GPIO_Init(GPIOG, (GPIO_Pin_TypeDef)GPIO_PIN_0, GPIO_MODE_OUT_PP_LOW_FAST);
GPIO_Init(GPIOG, (GPIO_Pin_TypeDef)GPIO_PIN_1, GPIO_MODE_IN_PU_NO_IT);
/* Init SPI peripheral pins */
GPIO_Init(GPIOC, (GPIO_Pin_TypeDef)(GPIO_PIN_5|GPIO_PIN_6), GPIO_MODE_OUT_PP_LOW_FAST); /* MOSI + CLK */
GPIO_Init(GPIOC, (GPIO_Pin_TypeDef)GPIO_PIN_7, GPIO_MODE_IN_PU_NO_IT); /* MISO */
GPIO_Init(GPIOE, (GPIO_Pin_TypeDef)(GPIO_PIN_5), GPIO_MODE_OUT_PP_HIGH_FAST); /* CSN */
/* ADC configuration -------------------------------------------*/
//ADC_Config();
CANMaster = TRUE;
/* Clock configuration --------------------------------------*/
CLK_Config();
//SPI Init (enable communication with L99PM62)
SPI_DeInit();
SPI_Init(SPI_FIRSTBIT_MSB, SPI_BAUDRATEPRESCALER_64, SPI_MODE_MASTER, SPI_CLOCKPOLARITY_LOW,
SPI_CLOCKPHASE_1EDGE, SPI_DATADIRECTION_2LINES_FULLDUPLEX, SPI_NSS_SOFT,(uint8_t)0x07);
/* TIM4 configuration -----------------------------------------*/
TIM4_Config();
/* Enable SPI */
SPI_Cmd(ENABLE);
/* Enable TIM4 */
TIM4_Cmd(ENABLE);
/* CAN configuration ----------------------------------------*/
CAN_Config();
/* Enable Interrupts*/
enableInterrupts();
// Set 40ms delay before starting communication during L99PM62 long open window
Delay(40);
/* Initialization of L99PM62 CAN/LIN transceiver */
L99PM62drv_Init();
// Set Auto Trigger by TIM4 timer tRefresh=10ms
L99PM62drv_WdgAutoTrigger(L99PM62WdgTriggerRefreshValue10);
/* Infinite loop*/
while(1)
/******************* Fro PWM ************************/
//dutyCycle_u16 += 10;
dutyCycle_u16 = 50;
TIM1_SetCompare1(GetCountForDutyCycle(dutyCycle_u16)); /*Timer1, Channel 1, PC1*/
//PWMInput_u16 = TIM2_GetCapture1();
TIM1_SetCompare2(GetCountForDutyCycle(dutyCycle_u16)); /*TIMER1, Channel 2, PC2*/
TIM1_SetCompare3(GetCountForDutyCycle(dutyCycle_u16)); /*TIMER1, Channel 3, PC3*/
TIM1_SetCompare4(GetCountForDutyCycle(dutyCycle_u16)); /*TIMER1, Channel 4, PC4*/
TIM3_SetCompare1(GetCountForDutyCycle(dutyCycle_u16)); /*TIMER3, Channel 1, PD2*/
delay_ms(1000);
while((TIM2->SR1 & TIM2_FLAG_CC1) != TIM2_FLAG_CC1);
/* Get CCR1 value */
PWMInput1_u16 = TIM2_GetCapture1();
delay_ms(10000);
//delay_ms(10000);
StartupCompleted=1;
if (StartupCompleted==TRUE) /* To allow leds display at startup */
/* CAN test mode */
if ((CANMaster==TRUE)||(ReceptionEnable==TRUE))
CAN_Task(PWMInput1_u16);
