PWM generator with PIC16F1827
john120
Banned
Full Member level 5
Hello every body,can some body help me to generate a PWM signal on the two pins of PIC16F1827;I want to use those signals for controlling my two IGBT which makes a half wave DC/AC Converter.
As hope you get the point those two signals might be in phase shift of 180 degres for making a complete alternative signal.
Thanks for the help.
Hello there,
I have attached one sample code here . it might be helpful for you.
Best regards,
  • 08_PWM.zip
Is it possible that I can use this signal you generated to control two IGBT in half wave dc/ac converter?
Thx
I am opening the link but reading is not possible because of some special functions required.Can you please guide me in ccs c compiler to write the same code ;I want just to generate two PWM signal which I have to apply on the driver then those drivers goes to the MOSFET for making up a DC-AC Converter.
Is someone has any idea on how the 50HZ on the output are found because I use the PIC which control the H-Bridge at high frequency.
Thanks
