Puzzled by a stepper motor
bobsun
Full Member level 2
I would like to ask a question on stepper motor.
I have recently bought a new permanent magnet stepper motor. According to its datasheet, it requires two poles to be driven simultaneously to rotate.
I was not able to figure out its internal magnet and electric pole structure. Could anyone infer it out?
Bob
Reactions: bobsun
    bobsun
The following is one of the most comprehensive tutorials on stepper motors available online:
Do you have the datasheet for your stepper motor? What is the make and model?
BigDog
Reactions: bobsun
    bobsun
Alex,
If you look at the two examples of "Half stepping" in the "How Stepper Motors Work" link, either for one-coil or two-coil excitation, through the steps the number of poles that are being excited is are not constant. It changes in a pattern like "1, 2, 1, 2".
But for the motor I encountered, the datasheet requires at all four steps driving two poles, although with direction change. I was not able to figure out its internal structure.
Is there any one help able to dissect it by analyzing?
Bob
prmurthy,
In you linked PDF I found the following example:
I don't under how "Normal full step" in the example works. Is there any animation for that?
Bob
It's a simple full step pulse scheme, which can be driven either to one (called "wave drive" in your scheme) or two coils ("normal" full step). Driving both coils results in slightly lower copper losses due to a higher duty cycle. If you sketch the flux vector, it's still rotated by 90 degree (electrical) steps.
Reactions: bobsun
    bobsun
See
You are using
Terminal 1a + + - - + + - - + + - - + + - -
Terminal 1b - - + + - - + + - - + + - - + +
Terminal 2a - + + - - + + - - + + - - + + -
Terminal 2b + - - + + - - + + - - + + - - +
You change the polarity of one coil in each step, this is full step drive
Alex
Reactions: bobsun
    bobsun
prmurthy,
Bob
Bob please co-relate with your image that yo have provided in the begning. Both are same. FvM has explained.
Reactions: bobsun
    bobsun
FvM,
I got it, thanks.
Bob
---------- Post added at 22:44 ---------- Previous post was at 22:43 ----------
purmurthy,
I could run it with full-step now, thanks.
Bob
How are you driving your stepper motor, with MCU or dedicated driver module?
BigDog
Reactions: bobsun
    bobsun
bigdogguru,
Sorry for my delayed response.
I am driving motor with a MCU, and is in full-step mode. There is a L298N H-bridge to control the current direction.
Bob
Reactions: bobsun
    bobsun
bigdogguru,
Thanks for the links. I will have a look at them.
Bob
