wls
Member level 4
Hello all . I am doing a 10 bit SAR ADC . Main blocks are (1) Zero off-set comparator (2) Resistor based DAC (3) SAR logic ( synthesis and P&R ) .
At cadence schematic the simulation with typical model , temp 27 it runs okay . Even running using calibre netlist with no parasitic , simulation is similar to that of circuit/gate .
The problem is post simulation with parasitic ? The simulation run correct at higher temperature ( our own model process run 0 to 125 temp , " best 0 , typical 25 and worst 125 " . The post simulation run okay with temperature 125 but not correct if lower temp used ? Why is this happenning ? When this happen does it mean it will fail during tape out ? Is it setting or model related problem ?
Regards.
Regards.
