push button with pic16f887
charu2539211
Junior Member level 3
hi
i am using a push button connect to the pic16f887. this is my code in assembly language
i have intialised portd0 as input port and portb as output port.
BANKSEL PORTD
BTFSS PORTD,0
GOTO LEDSEL
;;; delay????;;;
BTFSC PORTD,0
GOTO LEDSEL
GOTO DEC1
LEDSEL
DEC1
so when i press the push button it should go to DEC1, else it should go to LEDSEL
is my program right???
and do i need to add a delay in between?? if so how much???
Your code is not compelete, from what I see, it will run only once and doesn't loop.
Depends on your application, use an interrupt and connect the button to the interrupt pin, or use a loop (resource hogger) if you're connecting it to an IO pin.
Otherwise your code is ok.
    V
