Purpose of Reset Synchronizer
muni123
Member level 3
India
we use a reset synchronizer in an asynchronous reset design such that it doesnt issue reset in recovery or removal time.
Cant we use a synchronous reset in a design instead of going for a reset synchroniser in asynchronous reset design?
What would be the real purpose of reset synchronizer?
nsingh95
Member level 3
bangalore
You can use but it is not good to practice.
Suppose you use a syncronous reset in your design and your design gets reset due to some reason then the system will get reset on the next edge of clock[+ve or -ve] which nobody wants . So, the proper reset feature must be as soon as the reset is applied , your system must reset.
Thats why we generally use async reset .
Hope you are clear with this.
