pulse generator in vhdl
ZeleC
Full Member level 5
pulse generator vhdl
hello anyone got links or app notes for doing a edge triggered pulse generator to be implemented in a cpld
thank you
vhdl pulse generator
You can use asimple code to generate this. Make an output high at the clock' event and after a fixed delay pull it down. This acts like a mono shot.
B R M
pulse generator vhdl code
Hi ZeleC,
Couldn't you reuse this ?
:wink:
well r_e_m_y im trying to search some another code
well there is a problem with such a trigger generator
suppose that i have a 1 second clock
if i want for example a pulse of 2 sec well i will not get exactly 2 sec i will get 2 sec + ,because the trigger pulse is in between
wht i want is when the cicuit is just trigger to start counting.
i hope that you understood what i mean .
and hope to have some ideas from you friends .
thank you .
