[SOLVED] PT1000 sensor output flectional
Ranbeer Singh
Full Member level 5
Faridabad India
PT1000 sensor output fluctuations
Hello experts
I made a temperature display with PT1000 sensor. Display last digit is not stable. To the best of my belief it is the factor of voltage fluctuations. Anticipation i am displaying it with some delay in my codes. But I think it is not stable like other temperature displays. It changes last decimal digit in every second or half of second. I am displaying in 00.0 format.
I want to know.... How to handle experts for this?
Try to use Kalman filter
void KalmanFloatCalc (KalmanFloatStructTypeDef * KalmanFloatStruct)
  KalmanFloatStruct->Result = KalmanFloatStruct->K * KalmanFloatStruct->Value;
  KalmanFloatStruct->Value = 1.0 - KalmanFloatStruct->K;
  KalmanFloatStruct->Previous *= KalmanFloatStruct->Value;
  KalmanFloatStruct->Result += KalmanFloatStruct->Previous;
  KalmanFloatStruct->Previous = KalmanFloatStruct->Result;
typedef struct
  float Result;
  float Value;
  float Previous;
  float K;
}KalmanFloatStructTypeDef;
Reactions: Okada
    Okada
It's looking good but how to use it? I have a float value only.
Can you explain me?
How it works?
Each time you launch KalmanFloatCalc function, the Result value coming closer to Value. As low you will choose K, as smooth will be this movement.
First you should define an instance:
KalmanFloatStructTypeDef KalmanStruct;
Then you full fill it with values:
KalmanStruct.Value = <you input value from ADC recalculated to temperature>
KalmanStruct.Previous = Value; // initial value to force it start closer to result
KalmanStruct.K = 0.1; // this you will have to choose yourself, 0.1 is a good value for 10 time averaging
Than you run the KalmanFloatCalc with parameter KalmanStruct at least 10 times and update the Value. You will see, how the Result will move to Value smoothly.
hello,
it is an exponential filter. I used it in 80 years on a PDP11 application Block Langage !
The filtering depends of the periode timing algorithem execution.
but with a less academic rule , as Easyrider83 presentation.
this excel sheet can show the result of filtering,
depending of K factor K=0.0 value is NEVER uddated K=1.0 Value is NOT filtered
and depend interval time of execution
View attachment Filtre_Exponentiel.zip
float TF,Kfilter,TNow,TOld;
int FirstPass=0;
  while(1)
    M0=ADC_Read(0);
    TNow=(float)M0* 500.0/1024.0;   // 5V for 1024 pts  LM35 =10mV/°C so scale is 500°C
   if (FirstPass==0)
    TOld=TNow;
    TF=TOld;
    FirstPass=1;
    else
     TF= ( TNow * Kfilter) + (1-Kfilter)*TOld;
     TOld=TF;
    UART1_Write_CText(" ADC0 value = ");
    WordToStr(M0,CRam1);
    UART1_Write_Text(CRam1);
    UART1_Write(TAB);
    fltToa (TF, txt,2);
    UART1_Write_Text(txt);   UART1_Write(TAB);
    UART1_Write_CText(" Degres\r\n");
    Delay_ms(500);  // <- this delay is important for the filtering effect
    LD0=!LD0;
