PSU Designer version 2.0.1
Robin Hood
Full Member level 4
Full Member level 4
Sherwood forest
psu designer
PSU Designer II is designed to help you with the design of simple linear (unregulated) mains power supplies, as often found in tube amplifiers.
Key features
Rectifier types: Solid state, Vacuum tube types 5AR4, 5R4-G/GY/GYA/GYB, 5U4-G/GA/GB, 5V3-A, 5V4-G/GA, 5Y3-G/GA/GT, 5Z3, 6AU4-GT, 6AX4-GT/GTA/GTB, 6CA4, 6D22S, 6DE4, 6X4, 6X5/GT, 6W4-GT, 83, EZ80, EZ81, GZ33, GZ34, GZ37.
Rectifier configurations: Half-wave, Full-wave, Full-wave bridge, Voltage Doubler.
Filter configurations: Simple C filter, C/R/C, C/L/C and LC (swinging choke). ESR in capacitors can be catered for, as can winding resistance in chokes. Chain as many filters together as you like.
Outputs: Graphic representation of voltages and currents present in the power supply.
Tools/Utilities: Transformer off-load voltage calculator, transformer source impedance calculator.
Other features: Online context sensitive help. Ability to add extra rectifier types.
System requirements
Operating system: Windows 95, Windows 98, Windows 2000 or Windows NT.
Display: 640 x 480 or greater, with 256 colour capability, or greater.
Memory: As per minimum requirement for operating system.
Download the Software:
https://www.duncanamps.com/psud2/psud2_setup.exe
Info:
https://www.duncanamps.com/psud2/index.html
