Hello,
I just would want to implement a simple expression on a resistor value to modulate the value of the resistor with a pulse generator (for example). I managed to do it with LTspice
So I tried in the same way with Pspice but it doesn't work at all, it returns me an error :
* source TEST
R_R1 N16852 N15627 49.95+0.1*V(CDE)
ERROR(ORPSIM-16145): unknown parameter
The means to achieve arbitrary functional dependancies like this are the behavioral voltage and current sources BV and BI in LTSpice. Notice that a resistor can be modelled by a voltage source controlled by the current through itself.
Hello FvM,
I don't need Behavioral voltage to do it in LTspice because, by replacing the value of the resistor with a direct expression like mentioned in my first post works perfectly. But it's seem to be impossible to do the same with PSpice (Orcad product), and I have to it with Pspice. Any idea ?
I never have done something like this - however, I know that expressions in PSpice normally are written between these kind of brackets {}.
Perhaps you like to try it?
Hi, I'm not familiar with LTspice, but I noticed that CDE net name is in capital letters near source, ant in equation they are not. Can't this be misunderstanding during calculation?
